Best Exhaust Brand??
RE: Best Exhaust Brand??
ORIGINAL: Fictionnn
What is the BEST exhaust for the 1000rr? HP gain, Sound, Fitment, Price? I'm looking to buy but so many diffrent people say so many diffrent things someone please help me.
It's not the lightest exhaust, but since I wasn't going to install an undertail, I got it.
IF i ever get one, its going to be a Hamaguchi full Ti system
... look up Dyno charts @ www.1000rr.net courtesy of Brad from www.SuperBikeSupply.com whose pricing & customer service set the bar
The Erion full system in Ti is nice, really nice
Arrow full system is damn near the nicest thing you can get your hands on
HGA makes the best power, by FAR
We run the Arrow GP system, for the look and sound, it makes a bit more top end, but our motors are pretty much all around 180-200hp, so they need to breath a bit more than stock
The Arata and Sato I havent seen for the 1K, but have used them in the last few years, decent, not great, but decent. If you hadnt seen a works pipe, you would consider them awesome.
Be SURE to fit a Ten-Kate ECU if you do a full system, otherwise you lose power, as the ECU wont see the servo motor cycle
In its built in pre-test before run, all those noises you hear, are the self diagnostics for the ECU.
If you fit a full exhaust system, you can do one of two options, leave the servo itself in place, with just the cables disconnected, or fit the Ten-Kate ECU so that the system sees its self diagnostics satisfied.
Without the full run of diagnostics, the ECU defaults into a semi-limp-home-mode, that reduces power in all gears, at all throttle settings, compared to having the servo or ecu in place.
I havent tested this myself as all of our bikes are fitted with the ECU, this is directly from HRC, and Erion racing.
