Air Flap Mod./ lose power?
I was at my local dealer today and I was told that the air flap gives you your low end torque and he seemed to believe that I would be losing power by making this modification? Anybody have any input or proof to this before I do the mod?
RE: Air Flap Mod./ lose power?
Your local dealer is a retard , you can tell him I said that.
yep
too many dyno sheets posted across the web showing nothing but gains heres a link because i am feeling generous http://hooliganbiketech.dynup.net/ho...frameindex.htm then click on easy flapper mod back to back dyno runs with the only difference being the flapper is on and off with the flapper off he picked up 3 hp and 3 ft/lbs |
ORIGINAL: MgA_ODEN Your local dealer is a retard , you can tell him I said that. |
In this case why don't you be the judge !! reach in your fairing pull the vacuum line and stick a bolt in it!! Take her out and give er a rip down the street if you don't like it plug the line back in !! easiest mod ever and adds a nice tone ;)
I've seen this before and it could be true if the intire air box and intake track changed with the flapper. You can't close off one end and increase velosity as they say in the advertisement.
ORIGINAL: GEARHEAD69 In this case why don't you be the judge !! reach in your fairing pull the vacuum line and stick a bolt in it!! Take her out and give er a rip down the street if you don't like it plug the line back in !! easiest mod ever and adds a nice tone ;) +1 I did the flapper mod about 2 weeks ago. Can't say that I feel an increase in HP (my butt dyno is not that sensitive), but def can't feel a decrease either. Plus, as stated, it does add a nice tone. |
I had my bike for like 6,000 miles before I found out about this mod and Wow was I stoked after it was done !! Really seems like the mod is most noticable during throttle rolls in the lower rpm range say 4th gear @ 2500 rpm open her up and "GROWL" OH YEAH !!!!! Wished I would have heard about this one sooner!! Dude you can't go wrong best 5 minutes you've ever spent!!
ORIGINAL: Thack I've seen this before and it could be true if the intire air box and intake track changed with the flapper. You can't close off one end and increase velosity as they say in the advertisement. the snorkle does change at low rpms very small doors are open allowing air in at high rpms flap opens and the entire snorkle is free when you unhook the disable the flapper the snorkle is always open www.rogueracing.org has some detailed pics of the intake track with the flap open and closed |
I had this exact issue upon implementing nthe flapper mod. Lost low end torque. Put it back, and the front wheel is light.
Sure , it may get more power at a higher rpm, loss of torque for me. |
