Adding a slip-on...do I need a Power Commander?
I've got an '08 CBR1000RR (contrary to my username lol) and I'm about to order the Two Brothers slip-on. I've heard that just a slip-on will require adding a Power Commander but I can't imagine it affects air/fuel that much. Anyone know if it's really needed? Thanks in advance!
RE: Adding a slip-on...do I need a Power Commander?
ypu will see a gain in power with a PCIII but you would also see a gain with the stock exhaust and a PCIII.
You dont have t get one, but if you wanted to get one it wouldnt hurt.
All depends on what your looking for Verses the cash your willing to throw at it.
Personally i recon the bike has enoug power for 95% ofpeople out there (me included) but eveyone likes a great soundng exhaust
ORIGINAL: R6WS6
as for the PC as stated not required but you get to maximize the bike with or with out a pipe with a custom map.
yep as all stated above. Except I disagree about the power commander not doing anything fora stock bike. If you just download a map, then yes, it will only clean up the throttle response a bit. But, if you do an actual dyno tune on a stock bike with a power commander, you can see pretty amazing results. I've seen as much as 8 hp throughout the rpm range and a 6 hp gain on top end with an otherwisestock R6. You can also really clean the power curve for better drivability.
ORIGINAL: TK954RR
No it is not "needed", it will run just fine without. Slip on's alone are mostly for sound not performance, although it will breathe a bit better then stock.
ORIGINAL: justasquid
ORIGINAL: mexpipe
talking about a good exhaus what about the jardine RT1 foran 07,1000rr????
is it a good exhaust ??
