2006 Honda cbr 1000 battery wont keep charge
Old 09-18-2008, 10:39 AM
Richburg's Avatar
Default 2006 Honda cbr 1000 battery wont keep charge
I have a 2006 CBR1000 rr with only 480 miles on it, got it brand new in Nov o6. I have to charge my battery every other month because it dies, warranty is gone. Will honda cover this becase its a known problem?
Old 09-18-2008, 10:12 PM
Default RE: 2006 Honda cbr 1000 battery wont keep charge
No.
Old 09-18-2008, 11:13 PM
no, battery isn't a warrantied part.
Old 09-18-2008, 11:36 PM
jUSt go get some AA's from walmart and it will work HAHA!
Old 09-19-2008, 12:29 AM
TK954RR's Avatar
Jan 2009 ROTM
Rich if it is the battery you will be on your own. You may want to check your stator also though, i believe there is a recall on that, so it would be covered if thats why your battery is running down. I may be wrong, if so someone should tell me shortly.
Old 09-19-2008, 01:03 AM
480 miles in almost 2 years could be the culprit. If your bike sits for long periods of time, you might want to invest in a battery tender. Of course you could ride more often too. Short rides of only a few miles aren't enough to keep the battery charged. Charging systems on bikes aren't the greatest, and they have lots of other things to power as well ie; headlights, coils, ECU, stuff like that.
Old 09-19-2008, 01:45 AM
HAVOC's Avatar
like others have said if its the battery then no it wouldnt be covered. now if the issue is due to the result of a recall then honda should honor that without a problem. keeping your battery charged when not in use will help it from draining during periods of long inactivity also if you arent riding that much you should also invest in some pitbull stands and keep the bike up so that the tires dont get flat spots.... or just get out and ride more
Old 09-19-2008, 01:46 AM
HAVOC's Avatar
ORIGINAL: blkout15
you know these bikes are windup toys not battery operated geez
Old 09-19-2008, 02:12 AM
There are only two recalls for the 2006 1KRR. The fuel system, and wrong information for NHTSA in the manual. Found this on the Honda Powersport website.
http://powersports.honda.com/the_sto...ress_20125.asp
Old 09-19-2008, 08:51 AM
Richburg's Avatar
Thanks for the help, I do need to ride more. I will have the stator checked.
Quick Reply: 2006 Honda cbr 1000 battery wont keep charge
