2006 1000rr oil light on knocking when warmed up. HELP!!!!
Alright guys I have a 2006 1000rr
Let me start the story I had the bike 3 months and someone pulled out in front of me forcing me to lay the bike down on the right side startor side
Anyways it slid on that side for 150 ft then hit the dirt and grass for another 25 feet or so
Couple days later after I got out of hospital and out of my bed lol
I decided to check it out
The entire left side was full of dirt I took it to car wash washed all the dirt and all out of it,, the stator cover was chewed up had a Giant hole in it full of dirt
Washed it all out took it home parked it in garage for 4 months
I ordered all new plastics battery stator stator cover radiator lines and more
I installed stator stator cover radiator line drained gas new battery
And bike started up
I let it run for 15 min changed oil and filter agin
Agin started it up let it run intill warmed up completely temp gauge works
The bike hit 185 degrees oil light came on and started knocking it died right after
Drained oil changed oil and filter agin same thing 189 started making noise oil light came on dyed starts back up still the same
0-185 sounds great I don't get it
When I first drained oil it had water in it from pressure washing stator out
Any ideas and help wold be Appreciated
And bike started up
Remember, when the oil light comes on it means you have NO oil pressure. None. That is, of course, if the sensor is working properly and it sounds like it might be working since you hear knocking noises right after it comes on, and we all know knocking is not good. I wonder if you've gotten dirt into the oil passages somehow and when it's warm your oil pressure goes south.
