2006 1000rr cooling fan problem!!!!!!!!!!!!!
Hello guys I'm having some problems with my 06 cbr1000rr. Between 150-180 degrees my fan kicks on and stays on until I shut my bike off. Any ideas?
Have you installed any new parts lately?? Have you checked/changed your coolant fluids recently?
I installed a slip on and removed servo I had the fi light on thinking maybe that was the problem thinking maybe the light triggered some other fault so I ordered a servo buddy got rid of the light but still fan problems
Is your thermostat opening and closing properly? It could be stuck open.
I'm not sure? What's the easiest way to check it?
Start the bike from cold. The radiator hoses should stay cool then get warm fairly quickly when the motor reaches operating temp and the thermostat opens. If it gradually gets warm as the engine heats up, it's stuck open. If it doesn't get warm at all, then it's stuck closed or the coolant is not flowing.
Yeah I already did that they heated up I didn't think there was any other way to check just wanted to make sure it wasn't any different than a car. I ordered a coolant temp sensor today hoping its bad and maybe reading hotter than actual temp and kicking the fan on?? I dunno just giving it a shot lol
