'07 no pressure at clutch lever
Old 04-28-2010, 07:20 PM
DBEAU's Avatar
Default '07 no pressure at clutch lever
Hey,
My friend just acquired a 2007 cbr 1000 which has a hydraulic clutch. We've been bleeding it for about 20 min and we're not getting any pressure in the lever. I'm not very familiar with hydraulic clutches and am wondering if there is something we're missing.
So essentially, no pressure in the clutch lever, bleeding...bleeding...bleeding... still no pressure.
any advice would be appreciated.
Old 04-28-2010, 07:52 PM
DBEAU's Avatar
UPDATE: We fixed it.
For future reference, we bled the master cylinder from the banjo bolt and now it works like a charm.
Old 05-12-2010, 06:26 AM
cbrkg1000rr's Avatar
Default A million thanks
Dude, thanks for your solution. I had a similar problem. My clutch started engaging sooner a little at a time and so I decided to change fluid. Having never done it before I was a little iffy but did it anyway. Couldn't be any harder than brakes. But then NO PRESSURE!!!!!
was bleeding from slave and nothing just like you.
So googled and googled and finally stumbled across your thread.
Tried it and BAM!!!! worked. Thanks a bunch.
You probably saved me some cash I wouldn't have needed to spend.
Old 05-12-2010, 07:34 AM
chainstretcher's Avatar
Admin Emeritus & MVN
A mityvac is a worthwhile investment
Old 05-12-2010, 12:58 PM
I bought one of those and it didn't work. Just kept sucking fluid and air.
Returned it and got my $33 bucks back.
Old 02-23-2023, 03:16 PM
lowco83's Avatar
No pressure in my clutch
Old 02-24-2023, 06:25 PM
dannoxyz's Avatar
Have you bled in new fluid?
Might be master & slave cylinder seals are worn.
Also helps to bleed with slave higher than master. That way you're not fighting physics. Bubbles rising faster than you can push them down with bleeding. Easier to have slave higher, then bubbles and fluid moves in same direction.
guitarhawaii
12-12-2009 05:30 PM
Quick Reply: '07 no pressure at clutch lever
