jeason15 |
07-07-2013 08:52 PM |
the 2006 cbr1000 has bearing halves installed, and they can be spun. before you tear your motor completely apart, drop the oil pan and look for metal flakes and chunks in the oil, that is normally a tattletale. then, check your oil pickup screen for metal, and make sure its not clogged. normally, when you have spun a bearing, it is because of improper lubrication. That can be repaired, and if you are thinking of replacing the engine anyway, then disassemble the motor and check and see if your crank and cases can be saved. Lastly, the 1000 is the fireblade. the two are one in the same.
