05 1000rr stock suspension setting for track?
RE: 05 1000rr stock suspension setting for track?
at almost 190 lbs you will be hard pressed to set the front forks on a 1000RR
you need a 1.0 kg/mm spring and the 05 has .88kgmm springs
if at all possible you need to replace the springs with say ohlin springs
they are cheap and will make the world of difference on the track
you can change them youself if you have a decent manual
the best you can do without replacing the springs is dial in the preload pretty hard and hope for the best
sorry its the nature of these bikes
