wont push start
ok i got a 88 1000f for free from a friend it ran when i picked it up but the starter went. and the batterys dead so i tried to push start it but when i let the clutch out it just locks up the rear wheel. im not a little guy at 290lbs but the rear wheel will just lock up i have like an 8foot skid from when the tire locked up any suggestions?
thanks |
RE: wont push start
Try second.
Also bikes are dam hard to pushstart unless you are sitting on the seat so there is some weight over the rear wheel. Finally the cbr wont push start unless there is at least some juice in the batter to power the CDI. |
RE: wont push start
Did you try putting it in second or third gear? First gear has too much mechanical advantage to turn the motor over. Using second or third gear reduces the torque of the motor... plus it'll turn the motor faster than if the bike was in first. You said the starter went out?.? You can try tapping lightly on the starter with a small hammer and try to turn it over. Sometimes things wear out and lock up, but usually they wear out and get in a bind before they lock up. Tapping on it might loosen it up. If the battery is dead and you don't have a battery charger handy our bikes run on a 12-volt electrical system. So do most cars... you should be able to use some jumper cables to jump-start the bike also. Hope this was some help. Just don't try to pull start it:eek:! I knew an idiot that did it with his dirtbike. When he dumped the clutch the bike finally started and did a wheelie in =to the back of the truck at 45mph! The guy was alright but it's kinda funny to look back on.lol! Good luck on getting your free-be running!!!!!!
RE: wont push start
ok i figured out the starter is fine but when it goes to start it locks up. it locks up in the motor can anyone help
RE: wont push start
plus it'll turn the motor faster than if the bike was in first The engine should turn slower in second. I would put it in 6th just to see if the motor will turn over, are you sure the starter is not seized and engaged to the engine and you do need some charge to the battery for the CDI, but I would be a bit concerned about if the motor is not seized before worrying about batteries and stuff |
RE: wont push start
put the bike in 5th gear, get it rolling clutch in and let the clutch out. if it still locks up, the motor may just be seized.
| All times are GMT -5. The time now is 03:29 AM. |
