Where does this go?
Old Jul 18, 2011 | 10:19 PM
  #21
Sprock's Avatar
LINK if you are going that route
Old Jul 18, 2011 | 11:22 PM
  #22
ThaBrock's Avatar
on order
Old Jul 21, 2011 | 10:44 PM
  #23
ThaBrock's Avatar
Update: I found a kink in the fuel supply hose. IM A IDIOT!!!! but the tank vent was bad
Old Aug 12, 2011 | 10:57 AM
  #24
ThaBrock's Avatar
After much trouble shooting and playing with fuel lines I FINALLY figured this out.
I swapped the petcock and it dies no more. This was a great learning experience for me.
Now if I can only get enough gas to the carbs to get the RPMs over 10,000.
Old Aug 14, 2011 | 05:00 AM
  #25
kiwi JK's Avatar
I have found that an easy way to clear the internal vent tube up inside the tank is to get hold of a length of the old style spiral wound and very flexible choke,throttle or clutch cable,push this up the exit pipe,connest it to an old style hand drill and while turning the drill gradually move the cable in n out until you can hear it at the top of the tank next to the filler.You may have to have several tries in n out to get to the top as any rust n crud will have to be cleared as you go.
Old Aug 30, 2011 | 02:06 PM
  #26
ThaBrock's Avatar
I solved the sudden dying problem but still have a consistent bog at very high RPM. I know it's not getting enough gas.
Is this bike suppose to have a fuel pump? It doesn't have one.
What size i.d. fuel line should be on it?
Side note, the big runs PERFECT until pushed to a extreme RPM.
Old Aug 30, 2011 | 03:40 PM
  #27
robbiebgraham's Avatar
Originally Posted by ThaBrock
I but still have a consistent bog at very high RPM. I know it's not getting enough gas.
I had the same problem, low down was god but up high bogging down. I checked the carb float levels and they were way out. Number 2 was flooding and the others weren't right either!!! set them and now, what a beast!!
Old Aug 31, 2011 | 07:01 PM
  #28
ThaBrock's Avatar
Originally Posted by robbiebgraham
I had the same problem, low down was god but up high bogging down. I checked the carb float levels and they were way out. Number 2 was flooding and the others weren't right either!!! set them and now, what beast!!
What is the adjusting mechanism for the floats on your bike?
Old Aug 31, 2011 | 07:15 PM
  #29
I did as the manual suggested and you adjust by bending the valve needle holder until the floats are at the right height.
Old Sep 2, 2011 | 12:19 AM
  #30
ThaBrock's Avatar
I need to find that write up in my manual.
