what are you adjusting your rear shocks at?
RE: what are you adjusting your rear shocks at?
Rhino94, You said in your post "Standard on both" where did you get the setting information from? Could you tell me what they are? or are they different from year to year? (I have an '89). I want to return my settings to exactly what they were from the factory so that I have a reference point to go from.
Thanks
Rob
Thanks
Rob
The upper adjuster (spring preload) has a standard mark (std).
The lower adjuster (dampening) I set exactly between the end-positions. I dont know if that is standard but nothing else is said in the manual.
clockwise = softer ride, counterclockwise = harder ride
Edit: Nice bike by the way :-)
ORIGINAL: chesthing
Just curious what everyone sets their damping and spring rates to - I've set the damping to standard position and am 4 clicks in out of I think 36 positions.
There is a new fully adjustable GSX R1000 -04 damper waiting at the post office, I'll see if it could be used. I guess I have to use the stock Honda spring if possible since the geometry differs and the Honda spring seems to be very hard.
Hi Steve, Back off holiday?
The rear shock has 2 adjustments, an 8mm nut at the top and a cross type screw at the bottom (I hope thats what I'm trying to adjust anyway!)
The bottom one is seized on mine, so I suspect it may be pretty standard, maybe.
Rob
Rob
Hi mate,
Yeah, arrived back last night.
Just checked my owners handbook for the first time ever!! The bottom adjuster is for rebound adjustment. I'm gonna leave that one well alone I think as she handles fine at the moment. Could do with a bit more pre-load though. I've got the preload wound right up with just me riding so you can imagine, it's a bit soft two up with all the luggage. Time for a new hagon I think, just gotta convince my financial manager though
ORIGINAL: rhino94
Back to the subject, my preload adjuster has no standrd mark, so I took your advice and wound it out 4 turns from fully in and it seems to be OK, well I like it anyway.
Rob
