What does a stock 1000F show on the Dyno?
I've have searched for this info, and the numbers are either vague as to crank vs rear wheel or they are all over the board. The most popular horsepower spec seems to be 132 and 135, which I presume is at the crank (and I understand there may have been a couple of minor inprovements over the run). Then I see other guys saying 105 to 115 at the rear wheel.
Anyone know of any solid rear wheel numbers for horsepower and torque?
Remember that dyno numbers aren't comparable unless you're using the same dyno. On a Dynojet inertia style dyno (this is what most shops have) you'll see between 115-119 or so probably. I won't go into the whole Dynojet v. others dyno thing, but if you measure actual hp (not adjusted-for-inertial mass dj numbers) the CBR1000F's are probably right around 100-103hp imo. Mine is 106.5 on a no-fudge-factor dyno, with a pipe and jet work.
Anyway, the important point is that for comparison purposes, you need to have the same dyno and operator. To say that one bike is x hp on one dyne, then another person say their bike is y hp on another is completely without meaning.
(just a little 411 )
Guest
Posts: n/a
Yer , interesting discussion , but , its all a bit academic really ...
At the end of the day .... HP = pffftttt
100 - 105 - 110 - ?? ....even if you have a fully jetted seat cover, high speed front mud guard and wild red colored exhaust and a turbo sticker on your tank ... it don't mean chit unless you rip the gas back to the stop and let her rev to the dark side of the moon !! ...
I give my old girl a hammering prolly compared with allot of owners , but I still don't red line in every gear with the throttle torn off the bars ...
....well not very often officer ...
