What do I need to service? 1991 CBR1000FM 45000 Miles/ 72000 Km
Old 04-10-2007, 02:35 PM
SuperBigB's Avatar
Default What do I need to service? 1991 CBR1000FM 45000 Miles/ 72000 Km
Hi, I'm new at this forum, and found it while looking for some help.
I'm going to partly overhaul my bike verry soon, and since i don't have any history of what's been done with it in the past, i wanted some good adwise.
What i plan to do:
- Change engine oil and oilfilter.
- Change cam chain tensioner.
- Change cam chain.
- Check valves.
- Change breake and clutch fluid.
- Change front fork spring (to a progressive spring), seals and oil.
- Install dynojet kit.
- Install K&N air filter.
- Sync. carbs.
- New sparkplugs.
- Change exhaust (Two Brothers)
Now... What i wanted to know:
- Did i forget anything.
- Do I need to check more things?
What about the generator chain and oil pump chain?
- Does anyone have the the service intervals for this bike?
Thanks!
Old 04-10-2007, 09:02 PM
MarkR's Avatar
Default RE: What do I need to service? 1991 CBR1000FM 45000 Miles/ 72000 Km
Change Coolant, flush
Check that little filter under the tank on the right (cabie breather)
Replace fuel filter if you have one
Lights\Switches check
Old 04-10-2007, 09:46 PM
Trips's Avatar
Check Cam sprockets for wear
Oh and stay away from progressive springs IMHO.
Old 04-11-2007, 02:44 AM
whats this carbi breather mark speaks of?
mabe bleed/change fluid in the brakes grease any fitings/bearings you can find.
check for wiggle side to side in wheels.*wheel berrings*
brake pads? mabe install a shotgun holster
chain & sprockets?
Old 04-11-2007, 06:13 AM
MarkR's Avatar
On mine, when you lift the tank, right side over top of engine, I have a air breather
It has a cap underneath where a filter would go, mine had nothing so I made a filter from the foam that comes with PC Mainboards.
Note: On Holiday for a week, if you want to contact me, dial 555-FIJI
Old 04-11-2007, 10:06 AM
SuperBigB's Avatar
Why stay away from progressive springs?
Old 04-11-2007, 10:55 AM
Trips's Avatar
I cant be arsed going into a detailed explanation (its all on google and sites like racetech) But basically the springends up having too much movement and dampening becomes guess work. Say you have a linear rate spring of .8kg. Then it would be very easy to have the rebound dampning and the oil viscosity matched to the spring rate. But because a progressive will have a constantly changing rate it will only match the damening/viscosity at one setting. Say its a .6kg to .8kg progressive. If you tune the rebound to match the .6kg then it will be underdamped whenat max travel when riding hard. But it you set it to .8kg then it willbe overdampedand harsh when cruising. It you set it to say .7kg then it will be both overdamped and underdamped depending on how much the forks are compressed which is not good for trying to figure out how much grip you have when entering into a corner. Progressives are ok if you just cruise around on nice smooth interstaes but crap when going hard or with a pillion.
HTH
Boab
Rides
12-05-2009 09:42 AM
Quick Reply: What do I need to service? 1991 CBR1000FM 45000 Miles/ 72000 Km
