Wanting to find the alternator wattage output
Have a 1990 cbr1000f. I have been unable tofind the output of the alternator as far as wattage goes. Just trying to see what kind of gear i may be able to run, or if there is any extra output even to use.
Bob |
Your alternator output, is 55 to 60 volts, ac. Then converted with your rr. 14.5 to 16v.dc, To charge your battery and some to the lights, ect.
These alternator are getting so hard to find. FYI A good battery that has lots of amps. Is key here. You would have to hook up the items you want to use, and measure the reduced load, draw at the battery. To find our how much you are going to draw from the battery, and how much if any remaining from the stator, rr. |
Thanks for that Sporty. I am suprised though that no one responded that has ran heated gear to report any problems, or mods. I will change the lights to LED'S to help.
