Tyre repair kits
Tyre repair kits
I've had a look at a few tyre repair kits for use "on the road"... apparently the screw in rubber plugs are old school, now there's a new type that may need the hole in the tyre made larger for them to work... it still comes with a gaugeable regassing co2 cylinder and stuff.
The kit I am looking at getting is AU$42... any links or recommendations on any kits anyone has experience with would be appreciated.
If you don't have a tyre repair kit with you when you are more than 50km from your favourite bike shop... I am telling you now... you will regret it!
RE: Tyre repair kits
Hi,
If you have only a small hole for example nail or glass you need only one aerosol bottle and thats it. It is easy and quickly to use. For example:
http://www.holtsauto.com/products/index.html
It gives you also pressure as much as you need to drive on.
Only warning: it can blow up in very high temperature.
