Two Bros Slip on's
Two Bros Slip on's
I found a pair of Two Brothers slip on's. The price is decent, but I was wondering about jetting. Do you guys think that I'll need to re-jet or shim the needles to get keep the excellent throttle response I have now with a stock set up?
And let's say I do need to shim the needles, could it be done with the stock needles or will I need to get a Dyno Jet kit assuming there is one available?
TIA.
TIA.
RE: Two Bros Slip on's
You can shim the stock needles. I don’t think youneed to change main jets. I runned on stock jetting with a race like fullexhaust and the plugs looked very good, light brown-tanned. I drove the bike real hard for extended periods and tortured in also on track. I can assurethat the bike pushed very good and with agreat throttle response. It was provided with a KN filter when I got it,maybe that help some since the Cane have a real small air box, but I'm not sure since KN filters are debated and the stock filters should be fine.Itappears thatHonda has over-jetted the Cane to be on the safe side. If I remember right the jets where #122 on mine, and people having dynoed bikes after full exhaust change has ended up with #125 jets, which is amarginal change. You may need to adjust the pilot jets though, and raising the needles a few mm'sis always good. Try to avoid Dyno Jet kits; they have a reputation to not last for verylong and also to carve the non-replaceable emulsion tube in the carbs. It wasDyno Jet needles on my Cane when it came, but they where quite worn. The bike still runned great though, apart for a slight choppinesson very low rpm's (about 3 krpm).
