Tune up time
RE: Tune up time
Change the oil, plugs and filters. If the coolant was done last year then that should be ok. A Quick of the brakes (including the fluids) and shocks and to see if all bolts are tight and tyres are at correct pressure If you want to go further then get a dyno test done at your local garage and they will fully set up your carbs. Then your away. Happy riding.
[sm=bounceybounce.gif]
RE: Tune up time
[align=left]How's your air filter look? Check the thicknes of your brake pads. Lube your throttle, speedo, and choke cables. Check bulbs. Check the pressure in your forks. Check brake hoses for wear. Dynotuning is a great idea! Don't forget to lube your chain.
[/align][align=left] [/align]
