time for new oil
Old 08-25-2008 | 07:51 AM
puma690's Avatar
Default time for new oil
thinking its time to change engine oil... 89 cane... any suggestions on how much i will need and whats good and bad...much abliged...
Old 08-25-2008 | 08:10 AM
Default RE: time for new oil
Take the time to read this article. It's long, but worth the time.
http://motorcycleinfo.calsci.com/Oils1.html
Old 08-25-2008 | 08:57 AM
knagy389us's Avatar
ORIGINAL: idodirt
+1 on this link, very informative. Personally I use Shell Rotella-T and the SuperTech filter from Wally Mart.
Old 08-25-2008 | 08:58 AM
puma690's Avatar
[8D]well u right about one thing...it sure is long...will give it ago...
Old 08-25-2008 | 08:59 AM
MarkR's Avatar
4Litres for a 94' with some left over.
change every 5000'km or less
dont run it low or over fill it.
dip stick is messured with out screwing it in
any oil is better than no oil
change the oil filter every time, some people say every second time.
but, you probably know all this. .
Old 08-25-2008 | 09:04 AM
bluebeard's Avatar
I haven't read the article above (I'll do that in a bit). When it comes to oil in a bike I, like so many others will always use the best "motorcycle" oil that we can afford. We all have our preferences but as long as it's oil for a motorcycle not a car you will be ok. Change it regularly too. Due to the high rpm, tight tolerances & the gearbox 5,000Km is more than long enough. Most times when you buy good oil a filter is also included. Use it.
If you change the oil & filter then 3.8 litres should do the job. i.e. one 4 litre container is enough. Hope this helps.
Old 08-25-2008 | 09:09 AM
puma690's Avatar
ah ha markr... always wondered wether dipstick was measured screwed in or out...thats cleared that up thanks..
Old 08-25-2008 | 10:45 PM
tallenuf's Avatar
Stay away from oils with friction modifiers in them, such as PTFE. These will wreak havoc on a wet clutch. Most oils with friction modifiers are advertised as "fuel saving" oils, great for cars suck for bikes with wet clutches. Also, it seems that several members report less chain rattling noises when using 20W-50 oil. I'm going to try this next time I change mine.
Old 08-27-2008 | 12:21 AM
ORIGINAL: puma690
After you've read it, I'd be interested in what your opinion is. Also check out his oil filter article as well.
corcoraj
09-15-2009 04:23 PM
Pauly_V
12-11-2008 08:10 PM
VP
09-14-2007 10:56 PM
DJ SLYKE
06-02-2006 12:45 AM
