Sump Pan Off.... What Now
I finally started work on the bike, it has taken nealry 3 months to get going, I still have panels off being repaired, but today I removed the sump pan because the gasket was leaking.
Is there anything I should look for while it is off and how do I remove the old gasket
Thanks Guys
Aussie Johnno
Thanks Guys
Aussie Johnno
Remove the old gasket with something softer than the metal it's made of , you don't want scratches or gouges .
If you've got a really old blunt flat blade screwdriver or scraper use that but carefully.
If it's leaking because the sump pan is already scratched , you can put a large sheet of fine sandpaper on a flat surface and put the sump pan upside down on it and gently rub the scratches out , but do it evenly , you don't want a wobbly edge either (hence the flat surface).
Have you downloaded the manual? I think all that type of info will be in there.
Check these out:-
Check these out:-
Try using petrol to remove the old sump gasket..................water won't move it at all !
I would also wipe the pan out as good as you can of any little bits if there are any, and let the pan dry really well from the water you have in it (from the bucket thing). You don't want to have water in your oil.
As far as other stuff to check, I can't really think of anything offhand.
