Starts when it feels like it.
Hi All
I have a CBR 1000 F 1988;
After some help Please its driving me mad.
It only starts when it feels like it.
I have had carbs cleaned and balanced and new plugs.
If iam lucky it will start and run on all four but if it does start it normally runs on 3 cylinders.
Most of the time it just wont go.
Help Please
Regards John
Help Please
Regards John
John, first you need to figure out if you have a fuel or electrical problem.
The very first thing I would do is check to see if its getting fuel.
I'm willing to bet you may have a bad fuel pump. I would disconnect the lines and see if its pumping. If its not, I'd go gravity feed. If it is pumping, check for clogged lines.
Check the pump first and report back.
I'd spray some of this stuff in the carby intakes and see if it catches
https://www.nulon.com.au/products/Ae...Engine_Starter
eye toke
07-19-2006 03:28 AM
