Starter sprague? dampener? how do I narrow my problem down?
I have a 91 that recently turned off on me at a stoplight and I have only been able to get started once since briefly before it shut off again. He's the backstory so you can get a better picture. I bought a used cbr1000 a few months ago and didnt have any issues with it. When it turned off on me, I first checked the battery and oil (which was pretty low), changed the filter and put new oil. It started and ran for a few mins but eventually died out. Now it makes an aweful screeching noise when hitting the start button. I found a youtube
If that is the sound it is the starter clutch/alternator damper assembly.
Start reading here and post up any questions you have. https://cbrforum.com/forum/how-tos-8...uccess-139015/ Photobucket's greed has ensured all photos have disappeared so I will try and find the original and relink. Cheers, SB |
+1 on what Seb said.
Also a quick test is to see if the bike will 'bump' start. If it bump starts no problem, then that points to the starter clutch, if it won't start on a bump, then it might be something else. |
I looked thru the post by SB, but the link for Stus "Replacing the alternator damper on your CBR1000F Honda motorcycle" was dead.I read through the other links, but I believe that those would be for later steps. Imma see if I can find a working link or writeup anywhere online, but Im still kinda stuck
