-   CBR 1000F "Hurricane" (https://cbrforum.com/forum/cbr-1000f-hurricane-38/)
-   -   Starter Button Help (https://cbrforum.com/forum/cbr-1000f-hurricane-38/starter-button-help-154873/)
Red97tib 08-30-2016 06:20 PM
Starter Button Help
1 Attachment(s)
Ok, so I finally go the Hurricane to start and ride around, it only took years of arguing. The only thing left to fix was the starter button sticking. So I took it apart and found a nice mess of spider webs and dirt and stuff. Like most of this bike.
Well the switch came apart easy enough but the spring just fell out. Can anybody tell me where this spring goes?! I'm totally confused on its location. I've tried everything I can think of. Seriously this is my last piece to get this thing completed and I don't want to spend $30 on eBay for something that should go back together. Please Help. Picture of spring and half the switch attached.
Sebastionbear1 08-31-2016 04:52 PM
Bugger!
I spent a few minutes looking online for you (not going to pull my switch to pieces because the spring may fall out!).
Found this........ Starter Button Maintenance on Valkyries
It's Honda but not CBR1000F but the principle 'may' be the same. Enlarge the photos and study how the spring is placed.
Hope it helps.
Cheers, SB
TimBucTwo 09-01-2016 08:59 AM
From your photo it looks like there is a post next to your left thumb that is just above the 'S' in the word [START]. It looks to me, that post would go inside of the spring in a way to push the button in an outward position.
https://cbrforum.com/forum/attachmen...0-18.00.29.jpg
In the left side of the photo provided by SB, you can see that post with the spring around it. The yellow arrow with the words,'Tabs are fragile!', just about points to it.
http://www.rattlebars.com/mtz/1800button.jpg
I hope this helps.
Red97tib 09-06-2016 06:37 PM
Thanks for the replies. The coil of the spring does go around the post and the 90 degree section goes into the switch itself. I have reassembled and it works better than ever. Thanks for the help guys.
