sprockets
Old 07-22-2017, 04:35 PM
boru's Avatar
Question sprockets
hi all,
i am going to replace both front and rear sprockets and a new did chain.
first time on this bike!!
any best procedures?
any help welcome!
Old 07-22-2017, 07:24 PM
TimBucTwo's Avatar
Should be straight forward boru. What type master link are you using?
The rivet type needs to be expanded but not over expanded to where it cracks.
The clip type needs the leading end to be the closed end of the clip.<-VERY IMPORTANT or it will come off during acceleration. Also do not spread the clip with a screwdriver. Instead, snap it on with pliers by having one jaw on the pin and the other on the closed end of the clip.
Old 07-22-2017, 07:57 PM
boru's Avatar
cheers timbuctwo,
the chain came with a rivet link and ive ordered a riveting tool.
but the chain on the bike is a split link.
so this is new to me!!!!
Old 07-23-2017, 09:01 AM
TimBucTwo's Avatar
Because you are removing the old chain and link, you can remove them in the easiest way. Grind, cut or actually use a screwdriver on the clip link. I find it easiest to use pliers to remove the clip.
You may find this video useful. I don't necessarily agree with everything he says but for the most part I do.
Old 07-23-2017, 02:21 PM
boru's Avatar
cheers timbuctwo,the riveter ive ordered is an easy riv 5 by AFAM.
seems easy to use and not over tighten if thats the right word!
ive watched a lot on youtube and they show you how to use it.
Old 07-23-2017, 02:23 PM
boru's Avatar
just noticed that was my 100!!!
Old 07-23-2017, 02:28 PM
boru's Avatar
any info on changing the sprockets?
Old 07-24-2017, 02:09 AM
CaBaRet's Avatar
Hi , I always leave the chain on then crack the front sprocket first, easier in gear and someone applying the rear break, can be a pig if you take the chain off, but I assume that's how you would have done it
Old 07-24-2017, 07:25 AM
TimBucTwo's Avatar
Congrats to the centenarian. lol
If you still have the factory front sprocket on. Or a factory spec replacement, it may have the ring guide and damper (GUIDE, RING 23820-MM5-000 / RING, DAMPER 23821-MB6-000). The replacement will most likely not have the bolt holes for it. Don't worry, it's not needed.
I agree with CaBaRet. Pull the front sprocket first, loosen the front sprocket first and then pull the chain and rear wheel. That front sprocket bolt can sometimes be a bit hard to undo.
Micro Rotors
10-26-2007 08:32 PM
Trips
09-21-2006 01:23 PM
93CBR1KF
08-10-2005 11:37 PM
BlindLOKI
05-01-2005 10:42 PM
PiMpBlueF2
03-10-2005 10:47 PM
Quick Reply: sprockets
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
