Originally Posted by Gentlemanjim
(Post 1043159)
Running hotter plugs can and probably will cause detonation and a holed piston. The rule of thumb is run the coldest plug that doesn't foul. I assume you are of the opinion a hotter plug will in some way provide increased performance un true.
the Pulstar plug only comes in the hotter DPR7ea-9 equivalent is why I'm asking about the use of hotter plugs, if Pulstar had a DPR9EA-9 direct equivalent ..... I wouldn't be asking the question and already have a set in there trying them out :) A hotter plug obviously won't yield performance gains and as you rightly say, "can" cause pre-detonation or hole a piston etc Question really was ..... has anyone run hotter plugs in the Hurricane ? Sounds like nobody has so I'll probably skip the idea for now I have Iridiums in both bikes and each set only cost twenty bucks :) Good Plug too :D |
Originally Posted by Sprock
(Post 1043243)
Wrong assumption as it's not what Pulstar plugs are about it's only because
Originally Posted by DragonCBR
(Post 1043310)
Incredible 20 bucks for a set when you think that all dinosaurs died for us to get iridium!
Those meteors did us all a favor and brought a nice thin coat of iridium as well yaaaaaay :D here's the LINK to the cheapo IX Plugs man |
The only time I needed to run a hotter plug was in the kid's CR80. Stock was an NGK 9 heat range. Always fouled. Switched to an 8 and never had another problem with the plug. We ran across other young racers with the same problem with the little CR. I would give them a slightly used plug and they would be good to go for the day.
