Sound Clips And 1/4 Mile Time For 1000F
Old Oct 20, 2008 | 08:31 PM
Zach's Avatar
Default Sound Clips And 1/4 Mile Time For 1000F
What Do These 1000F Run In The Quarter Mile Stock? Does All (Years)1000F Have The Same Horsepower? Or Is ThereOne YearThe Fastest? Also Post Up Some Sound Clips Of Your 1000f's Ill Have A Clip Of My1000
Old Oct 20, 2008 | 09:41 PM
Zach's Avatar
Default RE: Sound Clips And 1/4 Mile Time For 1000F
Error
Old Oct 21, 2008 | 03:06 AM
Shadow's Avatar
87/88 were reputed to be the quickest at 161 MPH. Later models were almost as quick, but had slightly smaller carb throats,(1mm less) but smoother power delivery. Better brakes as the models went on, 93 up had linked brakes.
My bike sounds almost identical to yours, but I have two pipes......
No idea on quarter mile times - check 'Essential Superbike' I think......
Probably 9's......?
Old Oct 21, 2008 | 04:23 AM
DragonCBR's Avatar
quater mile 10.64 i think, look in the readingI posted.
Old Nov 9, 2008 | 09:41 AM
Zach's Avatar
does anyone know the 1/4 time for sure? from factory... Thanks
Old Nov 10, 2008 | 01:12 AM
ebinz88cane's Avatar
Unless your motor is fresh from the factory floor, no mods, and you carbs, rings & valves etc havent seen wear then im pretty sure you 1/4mile is going to vary from what the manual specs, correct me if i'm wrong... Find your nearest drag strip and run it.
Old Nov 10, 2008 | 08:43 AM
Zach's Avatar
I Dont Have It Anymore, I Take It No One Ever Ran Theres At The Drag Strip?
Old Nov 10, 2008 | 08:47 AM
Griffin's Avatar
Nope.
Old Nov 10, 2008 | 09:10 PM
pacojoseph's Avatar
Published 1/4 miles times for a stock bike will run from high 10's to low 11's, depending on the source.
Old Nov 11, 2008 | 10:02 PM
Luis CBR1000F's Avatar
Check this video is very cool and they have some speed tests
http://www.youtube.com/watch?v=4OqblVF02Is
Cheers!!!
