Seafoam: Where to inject?
#21
Someone actually said to me I could consider mixing two stroke oil in my fuel 100:1 for a while, so all the rubbers and stuff is 'rejuvenated' a bit... well, not for the bike, but for my '84 Volvo.
Now, I'm no expert on the effects of oil vs. rubber, but doesn't oil harden rubber parts over time?
In other words; the above advise is BS?
#22
#23
Thank you all for the input.
I think I will buy some of the arisol and regular stuff in the bottle. I will spray some in my air box then do the fuel additive treatment at regular intervals. The carbs have not been touched for about 5 years. It still runs good, just some hesitation from a stop.
As for the oil, I will do as my common sence told me, leave it alone!!
Thanks once again
Paul
Thanks once again
Paul
#24
Add Seafoam Engine Treatment to your fuel tank, and your engine oil. It is a very versatile solvent. It is the same as adding engine oil flush solvents to your crankcase. When your oil turns dark, change it. The reason it is safe to add to your engine oil is because it is made with ALL Petroleum Products, so it does not affect lubrication.
Use only 1.5 Ounces per quart of engine oil.
#25
QUOTE The reason it is safe to add to your engine oil is because it is made with ALL Petroleum Products, so it does not affect lubrication.
So are ether and thinners - both petroleum products - but there's no lubrication in either of them.
Sorry, but you're not correct on this one.
I surely won't be adding it (solvent) to my engine oil in any way shape or form.
I'd rather run diesel oil and change it twice as often (which I do)
Oil goes "dark" when the percentage of suspended particles rises.
When it does, change the oil.
(the basic oil is still perfect;y good, but the additives degrade with use)
If there was a way to filter the oil and replace the additives efficiently , your oil would be good for the life of your bike.
#30
The writers got this one wrong, should have been Walmart.
I was trying to point out that you DON'T have to go to Walmart to buy Seafoam. You somehow fail to mention other stores. lol
YouTube - ‪Kmart Sucks!‬‏
