Rev limiter and other facts
I bought the February, 1990 issue of Motorcyclist magazine off ebay. They test the 1990 CBR 1000. Of course they loved it, but the magazine says this about the ignition:
"The ignition also functions as a rev limiter. Official redline is 10,500 rpm: if the rider overspins the mill, cylinders two and three are cut off while one and four are retarded. If the rider persists, the whole system shuts down at 11,600."
I never knew that, but as you all know, anything electric can and will go bad on a bike. I guess it's in the spark unit, and I don't know how it works, but I don't see why this can't happen at some other rpm. So if you experience this, check out the ignition.
Some other tidbits from the test: 10.74 in the quarter; 60mph on the speedo is actually 54.5; top speed-160mph; 37.8 average mpg.
RE: Rev limiter and other facts
Since the speedo reads off the front sprocket, you could get larger tires or change the sprockets. Stock on mine is 120/70 front, and 170/60 rear. They may make a 170/70 rear that would be slightly larger, but I don't know what front you could get. All you have to know is when you are doing 176 mph, you are really only doing 160. Doesn't yours use kilometers?
The speedo is cable driven off the front sprocket. A plastic coupling goes over the sprocket nut. The cable from the speedo goes into a geared 90 degree "transmission". A tab from this transmission goes into the plastic coupling. I've broken two plastic couplings. If yours needed to be super accurate, the little gears in the transmission could possibly be changed.
