Rev counter behaving oddly
Spark plugs, balancer, rev counter
I recently posted a thread 'Rev counter behaving oddly'. It was suggested I put some new coolant in so I stopped off at Halfrauds on my way home and bought some water and radiator flush.
When I got back on the bike the rev counter was up and down like a tart's thingies and I had to keep revving the engine as it felt like it was about to die.
When I got home I had a go at adjusting the balancer with the engine warm (had been resting an hour or so). No matter how many times I turned the adjuster, in both directions, I couldn't get the engine to whine. DOES THIS MATTER?
I also thought I'd check the spark plugs. They are all the correct shade of brown but THEY WERE ALL LOOSE. I was able to remove them without a wrench. I guess this was why the engine was misbehaving, but does it explain why the rev counter was over-reading?
I tightened them up, went for a short ride, and now the rev counter reads correct and the engine feels better. Am hoping this will fix the issues I've been having lately.
I can not comment on the balancer as I have no experience of that side of the bike yet.
How loose were the spark plugs? Finger tight or a slight turn of the wrench? Did they have coppaslip or neverseez on the threads?
Did you check the threads before replacing.tightening the plugs?
I would be very interested to discover why they were loose? When was the last time you or another bod worked on the bike?
Cheers, SB
Cheers, SB
I've heard of this happening on other bikes before. I wouldn't worry about it.
If it's not whining it should be fine.
As for the rev counter and the plugs - I'm not sure of the connection EXCEPT if the plugs were so loose that you were losing compression which would make the bike stutter and affect the rev counter. It's all I can think of.
Thanks Shadow, but as I said in my recent post 'spark plugs, balancer, rev counter' I found all the spark plugs were loose. I tightened them last night and the bike performed OK today.
Cheers, SB
Cheers, SB
I put the plugs in myself a while ago with a bit of copperease, not done any work on them since. I don't suspect there's anything wrong with the threads as they unscrewed by hand OK and went back in smoothly by hand, and I gave them an extra 1/4 turn or so until they felt tight enough.
It's possible that loose plugs explains why my rev counter was behaving oddly (as in my other post 'rev counter behaving oddly').
After tightening them up, the bike now rides OK, with the rev counter accurate and steady.
Guest
Posts: n/a
IMO..... Unless the back lash is causing a rumble ATM ?? ....as was said, it prolly is ok ...but , you might want to check it in the future as I believe that " no whine when tightened " may be a sign of no adjustment left ??
Glad she is behaving for you now though :-)
Kinda what I was thinking too, but what the hell; I know Jack about the dark side.
For all I know a loose plug lead on the No. 3 plug may explain why my wife is grumpy with me.
