Replacement rims
Good morning
I was able to speak to my contact in France and yes , they are making floatting disk that bolt on directly to the original rims.
here is the part number;FL55505 For the sc 21( that is what they call the hurricane over there)
and the link is:
http://www.franceequipement.com/
Have a good day
and the link is:
Have a good day
Hi welder, the pics and info are fantastic.. as I look at the pics, I see more and more mods( in my head)..
are those stainless steel lines? were you able to keep the LBS?
Did you use a kit? or did you do piece by piece? I was getting ready to replace mine with SS also but trying to find the fittings and lines to fit is tricky... Again more pics are begging to be taken and sent..
Welder, that bike of your is right on with the mods and updates...you said that a friend helped you with the wheels, was there a lot to the fitment?
ok last question.. Have you done any other mods to the bike?
My list is short but growing..new tapered steering bearing, Racetech valves and progressive springs for the forks, HID H/L, Leds in the F/R turns, black powder coated swingarm with spools and new bearings, new pegs, new dyna coils and 8.5 mm silicone wire (handmade) ,hanmade screens for the open holes on the sides, stripped and polished wheels, 2bro exhaust can with V& H headers,custom tank, glow gages, new bar weight ends, grips,cruise control, new alum radiator fan stahe 1 jet kit, k&n ..
Rims
Carl, thx for the info,
i think that my bike is an sc24 is a 93 . If memory serves correctly, sc21 were up until 92, then the newer style came into the picture.
I'll say it again, this forum and members are the best...always helpful,very engaging and awesomely enthusiastic to help and share and build!!!!
Art
Art
rims
hi sorry it took so long to get back with you the machining that has to be done is some of the wheel where the rotors mount to has to be removed so the the rotors will line up with caliper he was not sher of the amount time to get out your digital calipers i did notice that one of the spacers is smaller ( the left side if you are sitting on your bike )than the other not sher if thats standard hope this helps
Rims
Hi welder,
Thanks for the info. I finally got a rim from an 02. Any chance of some closeups of the brakes/lines?
Also any chance for pics of the wheel and rotors closer and directly from the middle?
Do you how much material he cut from the rim? Also saw that the spacers are different. Yup..Thanx again
Art
Art
