is this the rectifier thingie?
Old 09-20-2008, 04:21 PM
TimBucTwo's Avatar
Default RE: is this the rectifier thingie?
ORIGINAL: Shadow1
Sounds like your regulator's gone to the big "Boneyard in the sky"[X(]
www.Electrex.co.uk supply excellent units which start charging from around 1400RPM, unlike the OEM units which start around 3000RPM.Cost around $120 US
I agree. Bike runs off battery and depleats it with not enough juice to restart it.
Old 09-21-2008, 12:52 AM
Shadow's Avatar
Simple test : Charge the battery overnight, take a multitester and measure the output across the battery -should be +12.5V- if it's not,it's a battery problem.- THEN start the bike, and warm it up,and measure the output across the battery again. At 2500-3000RPM should be 13.5-15V.
If it's not, it's either the stator or the reg/rec.
Measure the output on the three yellow wires from the stator - should read the same for each, around 30V- if one is lower than the others, it's a stator problem.
If first two are OK(battery and stator), all that's left is the reg/rec.
Remember all three components should be working correctly Reg/rec, stator, and battery.- if not, you'll have problems. I ended up replacing all three to resolve my difficulty. I had cooked the windings on my stator, which gave a charge with a new reg/rec, but over time it caused the reg/rec to fail. Hope this helps. If you need more, PM me.
I used the diagnostic chart that Steve_Cardiff mentioned in earlier post above. Helped a lot.
graygeezer
07-31-2011 02:33 AM
cbrsingleside
04-28-2010 08:55 PM
rkgjr1981
F2 Tech
04-13-2010 11:46 PM
falieson
01-22-2010 12:40 AM
Junior
08-27-2006 01:25 PM
Quick Reply: is this the rectifier thingie?
