Rattle & Grind... a little help please...
Old Jul 23, 2008 | 01:01 AM
PatricksBBQ's Avatar
Default Rattle & Grind... a little help please...
I have just done a maintenance on my caine.
Oil & Filter
Check Pluges (Looked Perfect)
Clutch & Break fluids
Tighten Chain
Grease Chain
Synched Carbs
I have two priblems that may or may not be related.
Old Jul 23, 2008 | 01:02 AM
Default RE: Rattle & Grind... a little help please...
First Problem
Rateling form the valves I think. It was happeinig prior to the oil change but then it stopped. Now its happeing again. Not all the time though. When I sopt a t a light it's noticable.
What could this be?
Old Jul 23, 2008 | 01:05 AM
Second Problem
This is a new one.
Shifting from 1st to 2nd. If I dont shift hard enough it will slip into nutral. I cant always get it to go into 2nd so I'll slow down and then it goes into gear just fine. This really only haoppens when I'm really rolling on the throtel. All other gars are fine but 2nd is really being a pain.
Any ideas?
Thanks for the help once again...
Old Jul 23, 2008 | 03:02 AM
Shadow's Avatar
Maybe tighten up your linkage to the gearbox - may be loose.
Rattling could be valves need adjustment.........?
Old Jul 23, 2008 | 07:10 AM
GILL's Avatar
Hows the clutch on your Cane? If the clutch is not disengaging all the way you will notice it the most between the lower gears.
Ratteling could be CCT or valves as Shadow said.
And why does this forum suck so bad for posting all of a sudden????
Old Jul 23, 2008 | 08:44 AM
MarkR's Avatar
Cause the Dick who maintains it can't figure out how to pass text to the databas.e without screwing the sql syntax
Old Jul 23, 2008 | 10:09 AM
tallenuf's Avatar
Rattling if intermittent is likely the CCT. What year is your bike? The CC could also be stretched close to the limit making it tough for the CCT to keep all the slack out. Might be time renew both. +1 on Shadow's advice to make sure your shifter linkage is properly adjusted and +1 on Gill's advice to check out the clutch.
Old Jul 23, 2008 | 04:31 PM
Its an 88... with just over 15K.
How do I adjust the CCT?
How do I adjust thelinkage to the gearbox?
Is changing teh m a difficult task?
Im not sacred to do it I am just a litte un sure on how to proceed.... I wish that there were phone support for these things....
Old Jul 23, 2008 | 04:32 PM
Oh, the clutch seems to be fine...
And +1 on the "Dick that maintains it"
Old Jul 23, 2008 | 09:26 PM
Shadow's Avatar
CCT is not adjustable, P bbq
Linkage to box is behind the small foot panel, left lower side of the bike, on the gearshift lever.
Phone help ?
+27 31 7002803 = just remember we're 6 hours ahead.............
