Raising the Rear!
RE: Raising the Rear!
Hi Rob,
I`m going through the same thing myself at the moment.
1:Use a zx12 or zx9(Ninja).They are approx 20mm longer!!
2:Take your linkages to a machine shop and get them to turn the bolt into an eccentric adjuster and make the holes longer,when you turn this around it will effectively shorten the linkages raising the rear!!This carries the added benefits of being able to return it to the original ride height should you so wish!!
I hope this helps.
Simon.
I hope this helps.
Simon.
madkawa
04-11-2007 07:04 PM
