Radiator Fan Non-Functional
I made the mistake of riding my 1990 1000F doing a lot of stop and starts where i got it to the point of major overheating and steam everywhere.It got to the point where it melted the plastic Y union on the side and was leaking fluid pretty bad.And end result is that it killed the fan but i dont know where the malfunction is now.I replaced the entire thermo housing unit including the sensor and thermostat,the fan thermo switch on the radiator and have done all of the electrical tests to find out if any of the parts were bad.The thermostat and thermo housing switch were bad so thats why the replace but now all switches are replaced/tested and work fine.(The fan has always passed an electrical test)But still when i let it run and get it to temperature the fan does not come on SO what i was wondering is how can i bypass all of the possible problems and just hot wire the fan to the battery? Then use a toggle switch to turn it off/on. I saw that was used/mentioned in other posts but no explanation on how to hook that up.I will take it to a shop if i cant find the original problem but A)Id like to get her there on her own and B)Id like to be able to use her for awhile for some business that is pressing.Ideas?
02, bad, cbr, cbr1000f, check, electrical, fan, honda, makes, nonfunctional, radiator, raditor, switch, test, testing, thermohousingunit, thermostat
