Q: Clutch fluid problem.
how to remove the air from the clutch fluid tank ? i replaced the clutch fluid and now the clutch lever won't work and i did bleed so many times but nothing changes , any idea ?
There are quite a few threads about this if you search , but I can tell you now that air in the lines is obviously the problem ...
When you bleed the clutch , you need to put quite allot of fluid through to get all the air out ... You can try cracking the joints(bolts) in the lines to bleed to those points. (work your way down the lines to the bottom bleeder valve )... Are you using a catch bottle or container to run fluid into ?? Just keep pouring the stuff in the top and bleeding it out at the bottom and it will come good eventually ...but it will take a while .. |
:icon_ditto: Yep thats the go. I have my young bloke help me pour the fluid in and I just pump the chit out of it until it comes good. Doesnt take long at all. Good luck with it.
1 Attachment(s)
i bought a vacuum bleeder and now my clutch fixed not even 5 minutes..here's the tools..
Chit man ... we would have suggested a power bleeder of some kind if we knew yu wanted or could afford to buy one :icon_shrug:
and yer they are the way to go , but I really thought that you might want to learn the old school hard way first mate ...:icon_teeth:lol good to hear you fixed her anyways ....:icon_wink: |
i bought it cause i felt like hopeless haha its not really expensive, i paid 50 bucks at princess auto.
Yep, that's what I have too. It's a mity vac brake bleeding kit. $30 at sears.
