progress pics
some pics while i test fitted the body
the ugly yellow
fender
motor wrapped and waiting for gaskets(hopefuly fri)
3 pics with the pannels in place
me on the beast
didnt get the gaskets yet thats y the motor is still on the floor
the ugly yellow
fender
me on the beast
yea i realy want to go for a ride but i gotta figure out whats up with the carbs i cleaned them and im gona sync them i hope it fixes it. once warm it revs good till 4 grand then kinda dies off n comes back i think it may be cause im running it with the airbox off but not sure so tomor eve im gonna pull the carbs again to put the air box in and sync the carbs to see if that helps.
the jets are two sizes bigger then stock it calls for a 120 and mine has 122 mains i think the pilots are oem.
i did think about the smoked lenses but prolly wont pass state inspection with them that way.
Guest
Posts: n/a
Yer ... the air box off could be something to do with it ..but I doubt it ?
Jetting can take a little trouble shooting on most bike as you might know ...
I would think because the pilots are OEM and she is idling ok ?? that the mains may be the only cause ..
Let us know how you go once the air box is on and you have tuned the carbs mate ...
Good luck
Good luck
My experincefrom the past is that, if the carbs were jetted and sync'd to have an air box, then without it, the engine will act just like it does now. Put the box back, with the filter, and try it again. Ihave a feeling it will run just fine or at least much much better.
