Is it possible to use liquid gasket for the oil pan?
RE: Is it possible to use liquid gasket for the oil pan?
You can use RTV engine silicone or similar without problems. Don’t apply more than necessary though,a thickness ofa mm or twowill do fine on machined surfaces and use your finger to remove any silicone that hangs out into the crankcase before mounting the oil pan.You don’t want any silicone to come loose into the engine since it can plug the oil pump pickup.
Linky toa typethat I have used http://www.permatex.com/products/aut...one_Gasket.htm
