Poor performance
I'm sure that most of you guys have pushed your old girls to the limit? How fast did she go?
Some time ago we had kind of "top speed" run at the small local airport. It was about 1 mile / 1700 meters run with a standing start. They measured the speed at the 1700meters with a police radar. I only did one run but that was horrible, not sure whats wrong with the bike. My topspeed was amazing 216km/h.. Jesus.. My old old volvo would've been faster :icon_doh: Some years ago I was there with my ex Cbr 1000f 1992 and it was quite a lot faster going 240kmh.. My bike is orginally from germany and I think they used to have max power limited to 100hp? Or what could it be wrong, im sure it should go faster. :icon_hyper: Heres link to the results http://www.liy.fi/tulokset/index.php...ed&only=&rev=0 .. quite embarrassing :icon_badrazz: |
Hi Mik76 , are you complaining of general poor performance , or just disappointed with the results of your run?
If she's running well otherwise , then she may as you say be restricted :icon_sad: , otherwise there is a whole list of things to check , let us know what you mean :icon_wink: BTW welcome to the forum :D |
If she's running well otherwise , then she may as you say be restricted :icon_sad: I'm not sure how fast a restricted one will go, either. |
Thanks!
I think its running fine except it feels little bit slow. :icon_razz: At least when comparing to my old Cbr which was year older and had driven more. |
That power limit thing rings a bell for me. If it turns out not to be that, then I'd start with a compression test to rule out a couple of major things (worn rings, valve seats etc.) Does it burn oil or use more fuel than you think it should? If the compression is ok then you'll have to look at your carbs. It might run fine through most of it's range but could be off when you're wide open for a speed run....still good fun to have a blast on an air strip:D.
The limited power version is the German GII version. It actually sounds like it could be the case.
Here is a picture of some restricted carburetor tubes on a different bike, but it's a general representation of what you're looking for: http://www.mb5.co.uk/resources/Tune+10.JPG Also, I came across an article about a restricted R1 (from france) where Yamaha basically used bumpers on the carb butterflies to stop them from totally opening up. The owner was saying that his bike would get up there in speed (well over 100mph), but was struggling enough that he couldn't keep up with a 600cc Suzuki at top end. Interesting! The 150mph (240kmh) speed that you mentioned with your last bike is more like what it should be. Gearing can change that, but if your RPMs weren't topped out, that's not the case. I believe the restriction was 100HP to the wheel, which seems to make sense. Obviously other factors could come into play here (carb issues, etc etc), but I'd look at the possibility of restriction first since it's easy enough. |
Trout is correct - 108/110 BHP at engine, 100 BHP at the wheel, on some German models.
My top speed 261KPH at sea level, with bigger freeflow exhaust, Dynojets and a K&N filter. Your bike sounds as though it's restricted. Some of the bikes sold in Switzerland were also restricted, I've read. Check your sprocket size, too, may have something to do with it. I run 17/42 (standard) :) |
The first thing I would check is the ignition timing. If the timing mark is on the "T" mark at idle, and stays there when reving the engine, your pulse generator needs to be replaced. $50 bucks for a new one, and a simple replacement job. Makes a big difference in acceleration and speed when the ignition is advancing correctly. In 20 years, mine has gone bad twice. I think the engine heat gets to it.
Just looked my registration documents.. there it says 72kW :icon_doh:
Soooo.. at least it has been a restricted once. :icon_hyper: Must go check those carbs asap :icon_razz: |
Never would have thunk. They do that to our shower heads and toilets too. I rip them right out.
