Oil pump drive chain
Old 08-10-2017, 08:53 AM
bullroarer's Avatar
Default Oil pump drive chain
What are the parameters of the oil pump drive chain, only with my sump off doing the Cush drive rubbers on the white one, noticing the chain, although you cannot pull it off the back of the pump sprocket there is a little bit of slack in it as it goes up to the crank shaft....any ideas.
Thanks.
Old 08-10-2017, 06:11 PM
Sebastionbear's Avatar
Super Moderator / Welcome Crew Test Pilot, VIN & ROTM Sept 2012, Kiwi Translation Specialist.
Now, I'll preface this with the comment that I have no experience with the oil pump chain.
A quick search with Google Fu found this site: https://forum.motorcyclenews.com/top...l-pump-chain/2
And reading through it, this comment:
oil pump chain
Don't be in a rush to change it just yet. Because it's not critical for valve timing and it's pretty short so there is no noise either, it can run pretty loose. There is no service limit on the chain and it doesn't have a tensioner which does allow it to run on the loose side. To give you an idea of how loose it can run, the procedure for removing the oil-pump drive sprocket to get to the pump involves fitting a sprocket holder special tool, undoing the loctited bolt, then pulling the sprocket off the shaft 5-6mm when the chain can be simply lifted off.
Hope that helps.
Cheers, SB
Old 08-11-2017, 01:02 AM
bullroarer's Avatar
Thanks for that, I guessed it was not of huge importance
Johnny34
F2 Tech
01-25-2014 05:22 PM
lhall6649
F3 Wanted
10-12-2010 07:24 PM
bond67
04-11-2008 12:05 PM
cbr714
12-25-2006 04:36 PM
deathrock
06-26-2005 09:57 PM
Quick Reply: Oil pump drive chain
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
