Oil checking rules
Oil checking rules
Hi everyone,
I wanted to check the oil level on my 1000FH. I thought that to check the oil you unscrew the cap and then you dip to check the oil. I did that and it was below the second line. I screw it and then remove it and was nominal level. There is a considerable debate on this: Do we check the oil level with the cap screwed on unscrewed. Can someone throw some light on this issue? Thanks
RE: Oil checking rules
hello everyone.......
it seems i have a small dilemma....
IT REALLY MIGHT TURN OUT TO BE A LARGER PROBLEM BASED ON MY ANSWERS BACK.
i'm puting oil in my bike right.
changing the filter as well.
for some reason the oil is not reading in my mirror.(glass in which oil is visible through fairings )
maybe it was too full, right..... and i couldn't see the level because it surpassed the fullness.
i just dumped it out..... and it looks the same as when i had 3 (three) quarts in it.
what's going on???
1)not enough oil ???
2)just perfect, and just deal with the way the oil - screen looks.(glass)???
3)it's busted and leaking inside of the bike itself ??? [:@][][>:]
4)too much oil ???
5)glass is not registering ???
thanks for your time of day everyone!!!
(561) 827-3817
Brian Roomes
what's going on???
4)too much oil ???
(561) 827-3817
Brian Roomes
