Oh Dear!!!
Oh Dear!!!
Was out for a run with a m8 the other day on our CBR's. He then started complaining that his temp gauge was not working.
So thinking it may be something more serious i took the side panel off and checked the expansion tank, Empty, ... So let the bike cool down then removed the radiator cap.. No signs of fluid. Poured some water in the rad and low and behold it poured out the bottom of the fairing.....
It turned out to be the cylinder head coolant pipe..
As you can see from pictures below. so now i have my m8's very ill CBR sitting in my garage until new pipe arrives.
OUCH !!!!!
Lucky..................strong bikes these.
Do that to some other makes and you'll hear the crying from up the street.
Good catch - question ?
Couldn't you make a set of those out of copper pipe and braise them up ?- must be cheaper than 108 pounds. 2c worth, says he going to check his pipes.........
That pipe is toast! How could he not know? Was it sitting for a good while? That's crazy looking. I would think that the first pinhole would have shot coolant out all over the place.
Bolts right to the front of the block and connects to the hose at the water pump.
Where exactly does that part go?
Rubber hoses will get brittle with the heat. Copper tubing won't rust and shines up nicely too !
AND will improve cooling
BTW I would venture an idea that your mate used ordinary tap water - distilled water and anti-freeze shouldn't do that to the pipes..........???
A good plumber with a brazing torch should be able to make a set of those in an hour or less.
