New to me 96 CBR1000f
Old 04-17-2019, 09:28 PM
Sniper X's Avatar
Default New to me 96 CBR1000f
I got this 96 and its generally nice. I need to jet it for my altitude which is 5200-7000 ft. It came from sea level so sometimes refuses to start, has to run with the choke on, and stalls if it gets below 1000rpm. Should I start at two pilots and mains leaner? What are you guys living at a mike high using for pilots mains and needle positions?
Old 04-17-2019, 09:39 PM
Hey there. Welcome to the forum and congrats on the new to you bike.
If you are at altitude you will need adjust your carbs. I suggest downloading the owner's manual for your model. That will give you the info you need.
Also I would recommend a very thorough carb cleaning and syncing. That might help as much as anything.
Old 04-19-2019, 11:59 PM
Sniper X's Avatar
I'm also planning to replace the fuel pump. Anf filter. Do you guys know where I can get a pump? Is this the correct part number? 16710-MAL-601
Old 04-20-2019, 03:05 AM
CaBaRet's Avatar
Dont really know the CBR1000f , but I thought they run off a vacuum petcock valve ?, someone with a bit more intelligence will be along
Old 04-21-2019, 07:50 AM
jarvid's Avatar
Welcome Crew
While we wait for someone with more intelligence to show up, I will say you do not need a fuel pump, the MK3 did not come with one and people that have had trouble with the MK1 fuel pump usually just ditch it, as Honda did.
Your 96 is a MK3 so no pump.
Old 04-22-2019, 02:53 PM
Sniper X's Avatar
Thanks!!
Old 06-06-2019, 06:34 AM
GronkFries's Avatar
Yes, no pump, just vacuum valve - And for your future hassle free enjoyment buy a petcock rebuild kit. It's around 18 bucks - you will need it.
Old 06-06-2019, 07:33 AM
TimBucTwo's Avatar
Stock jetting should work. Go 2 1/2 turns on the pilots.
It sounds like the sync is out a bit. Your idle should be set to 1,200rpm.
Sniper X
04-23-2019 10:19 AM
dieselsmellsgood
06-29-2013 02:17 PM
hillbilly86
06-11-2013 09:16 PM
Stray Cat
06-09-2006 01:24 PM
Quick Reply: New to me 96 CBR1000f
