need gasket for slip-on,what can I use??
Old 08-15-2008, 08:42 AM
1991 1000F's Avatar
Default need gasket for slip-on,what can I use??
I just got a two-bros slip-on and I need to put a gasket or something else where the mid-pipe connects to the stock exhaust under the bike.
Any ideas on something Ican get from an auto store or something?
Midas maybe have somethin like this?
BTW..The stock is gasket stuck on,couldn't get that off.
Old 08-15-2008, 11:14 AM
GILL's Avatar
Default RE: need gasket for slip-on,what can I use??
I'd look around at a few exhaust shops to see if you can match something up. You might want to put on a bit of high temp silicone to ensure you have a good seal too. As far as the old gasket, I take a torch and heat it up good and red and pry it off with a prybar. Good luck....off to replace my cam chain finally.............
Old 08-15-2008, 11:25 AM
Part No 18391-MLO-003
ID 48.5mm
OD 54.5mm
Old 08-15-2008, 11:53 AM
1991 1000F's Avatar
Thanks for your replies.
I took the mid-pipe to Midas and the dude cut an aluminum ring that fits perfect on the mid-pipe.(free of charge)
Should work fine
I also saw on bikebandit that they have it for 20$
Oh yeah,good luck with your Cam-chain Gill........
Please report your ordeal with it.
Old 08-15-2008, 07:56 PM
bruiserc's Avatar
Like to see pics of the exhaust on the bike when your done. Please.
kahlilj
06-08-2013 01:36 AM
Jeff0044
01-27-2011 10:04 PM
malbojah
02-17-2009 05:17 AM
Sladkixxx
02-01-2009 09:29 PM
two240s
07-21-2006 08:55 PM
Quick Reply: need gasket for slip-on,what can I use??
