My Hurricane will no idle right
I start the bike up and it purrs like and kitten for 3 minutes then it just goes erratic, unable to hold steady revs, seems slightly starved then races ??
I'm in the UK but this CBR spec is for the US and i've never seen so many pipes come from the carbs to crappy emissions thingy me bobs before? . I've done a carb strip and clean, new plugs, freshly charged battery, checked all terminals, new filter ???? I'm baffled. advice required thanks |
Sounds like a air leak.
Possible stuck throttle body, stuck choke. |
Originally Posted by Sporty982000
(Post 1297498)
Possible stuck throttle body, stuck choke. Can all the tubes for emissions be blanked off to make it European spec or are the other components fixed to the bike like the canister ect? |
Originally Posted by Dvornitzki
(Post 1297492)
I'm in the UK but this CBR spec is for the US and i've never seen so many pipes come from the carbs to crappy emissions thingy me bobs before? . I've done a carb strip and clean, new plugs, freshly charged battery, checked all terminals, new filter ???? I'm baffled. advice required thanks All the emission hoses can give you vacuum leak problems, which again makes for a lean out condition. On my US/California spec '94, the system was all still in place. I did read where other owners had removed the PAIR/PARE? system and plugged the ports on the front of the head. Maybe see the search section of the forum. I don't own the bike or manual any longer so research is limited to my feeble memory. So check the tank vent and inspect hose connections thoroughly for starters. |
all good one hidden hose had popped off.
Good fix congrats
