my clutch is making me crazy....heeeelp??
my bike has been sitting for a while, it wouldnt stay charged, but i think i fixed that....however, once i got it starting again, the clutch wasnt working....the rubber boot that pushes in was ripped, i have replaced that. now it still has no clutch....u can pull the lever in and it wont even roll.....any clue?....btw its a 1994 cbr 1000f hurricane
RE: my clutch is making me crazy....heeeelp??
When the bike has been "alone" for a while the clutch plates get stuck together. I usually get them loosened up by jerking the bike hard front and backwards in 1:st gear a couple times with the clutch in. Just a tip if you know that the handle and hydraulic works as it should.
RE: im lost....please help
brook,
When you bleed it, does the handle go all the way down easy when you open the bleeder? Then after you tighten the bleeder, can you pump it up, so its hard to pull it all the way, then after you pump it up and hold it down, when you crack the bleeder does brake fluid spray out under pressure?
If it does pump up and spray out at the bleeder, it is not your master cylinder (the pumper on the handle bar). It is probably your slave cylinder (the clutch disengager) or you blew out your clutches.
Does your engine turn over when you roll the bike and kick it into gear?
WE NEED MORE INFORMATION!
