one word there Doug ........... WRONG
Multiple factors at play I'm afraid oxidation, deposits, thermal degradation, corrosion, shearing and contamination Contamination is a single factor in Oil Breakdown but not the only factor other wise you'd just be buying filters only |
Originally Posted by Sprock
(Post 935605)
Multiple factors at play I'm afraid oxidation, deposits, thermal degradation, corrosion, shearing and contamination Contamination is a single factor in Oil Breakdown but not the only factor other wise you'd just be buying filters only You are so....CORRECT...I have over 300,000 miles on the oil in my truck. I never have to change the oil, I just add some oil when I replace only the FILTER!!!! Thats what I have been saying, it is not the oil people should be worried about. Its the Filter!!! |
A buddy of mine bought some Mobil1 4T Synthetic oil and then he also had a Fram filter. A FRAM filter!? I just put my head down and shook in disbelief.
Well I'll pass on the Truck then Doug :D if she ever comes up for resale LOL
Note to self ....forget buying oil ..........just get a new filter every month |
(Post 935670)
Doug,
Just because someone is pushing a semi to 100-300k doesn't mean that anyone should be advised to do the same in their bikes or cars. Open your eyes, man.... seriously. What are you running like 16 gallons of HD oil in your truck? So I should run my KLR650 forever and never change the oil? Just the filter? Even though I KNOW the viscosity is ****ed in as little as 3,000 miles?? If it's true, I'm sure a LOT of pro engine builders would be excited to hear the news that oil changes are all for nothing. Just get a new filter and forget about your oil, people. That's a classic. |
I am using Rotella T in the Truck engine. One reason the Pro Engine builders cant do it is cause of the Thermo breakdown caused by the Heat. They run the dog crap out of the engine to get the most horse power.
We do not run the engines in cars, trucks, motorcycles on the road to the extreme levels of heat that they do. I am not saying that we can run our motorcycles and never change the oil and just the filter, You need a special filter to do that. I am just saying that people are so worrier about the oil all the time and they do not worry about the filter. I apologize I did not mean to :icon_hijack: |
You are one crazy bad ass mf threadjacking sob there ......Indy :D .........LOL
Good thing I know ya well enough to say that too :) But 1st statement you made was Oil does not break down or wear out, it just becomes contaminated. Then One reason the Pro Engine builders cant do it is cause of the Thermo breakdown caused by the Heat. There in I'm afraid lies a slight juxtapose ! (Love that word) :) ......... a conflict of sorts if you will. AND Hey Matt .......... see that's exactly the kind of OIL topic that got started. We have to blame you for this one ! LOL |
One reason the Pro Engine builders cant do it is cause of the Thermo breakdown caused by the Heat. Anyway, motorcycles and diesel rigs aren't anywhere near the same ballpark. Hell, they aren't even the same sport.. :) Shearing from wet clutches/transmissions, etc..... 1/16th to 1/30th of the oil capacity.... different bearings..... different fuels, etc. etc. (although with 16 gallons of Rotella T6 and some purolators, I can go over 100k miles on my CBR.... so that rig link isn't real impressive to me.. :D) What I want to know, Doug, is what filter I should be using in my CBR that's gonna make my oil last forever. How about the KLR? How will it restore the viscosity back to spec every 3k miles? How does a micron filter remove acids and stuff? (heck I can't do it with nanofiltration at work!... aka billionths of a meter pore size. Can't touch lignins or a million other things, either ) |
How does a micron filter remove acids and stuff? Thermal breakdown happens in every engine Mobil Oil Australia Limited Technical Bulletin #863 states: “…oil does not “wear out”, “break down” or otherwise deteriorate to such an extent that it needs to be replaced. What happens is that it becomes contaminated with water, acids, burnt fuel, carbon particles, and sludge so that it can no longer provide the desired degree of protection for engine components. But, it will be argued, most modern vehicles have an oil filter. Why does this not remove contaminants? The answer here is that a filter can only remove solid particles above a certain size. It cannot remove water, acids, or fuel dilution, all of which pass through the filter just as readily as the oil.” (Mobil, of course, is talking about the full-flow filter.) You are one crazy bad ass mf threadjacking sob there |
