Microfish
Hi there
Does anyone out there have a microfish for the 92 CBR 1000 and if so could I please get a copy. |
RE: Microfish
hey was- Try www.westernhillshonda.com. They are in my hometown, Cincinnati, Ohio USA. They cater to vintage Honda. Bought a set for my '79 CB750F a few years ago for $5.00. If you want a hard copy, print on paper, go to www.discounthondaparts.com and scroll / print the pages of the parts fishe that you want for free. They have the real Honda part numbers. Hope that helps.
RE: Microfish
You are aware that there are manuals in pdf format floating around this forum
RE: Microfish
ORIGINAL: MarkR You are aware that there are manuals in pdf format floating around this forum |
RE: Microfish
RE: Microfish
Thanks for the links but mine is a 1992 I think it myust be Australian only ???? as all the links say 1991 and 1993 they seem to be missing my model ??? its red and black
RE: Microfish
ORIGINAL: waz57 Thanks for the links but mine is a 1992 I think it myust be Australian only ???? as all the links say 1991 and 1993 they seem to be missing my model ??? its red and black |
RE: Microfish
Hi waz, Just checking through my manuals, and was woundering what your id nunbers are? as the 92 is not listed so I'm woundering if you could be either a 91 or 93 model.
sc09e-2200803 to 2205358 eng frame sc24-2200765 to 2205070 1991 sc09e-2400017 to 2403062 eng frame sc24-2400033 to 2402908 1993 If you check to see what your id numbers fall into then you might be able sort out what you need. Hope this helps as thinking about it then there are no asian numbers eithers, yet we know that they are out there. |
RE: Microfish
Hi Collector, I believe the 1992 model was only made in Australia, I don't know how many etc but have not seen many, about 4. They normally pull about $ 5,000 Aus with approx 90,000 Ks on the clock.
My Engine number starts the same as everyone else's but instead of being 22 or 24 mine is sc09e-230 etc and the frame number is odd to JH2S-C24 etc so looks like I am going to have a hard time find a parts reference book |
RE: Microfish
What does your local honda say about the microfiche? Maybe they could either give you(if your lucky) or sell you one. I'll give Lings a call on tues and see what they can turn up, theyalways seem to be helpful in that respect. It may well be that you will have to go to Japan and see what they can offer?
Will let you know how I get on waz |
| All times are GMT -5. The time now is 05:06 AM. |
