Low Gas Mileage
#21
Since I recently rebuilt the petcock I have checked it religiously after I ride and there is no leaks there at all.
Also I seem to be getting a slight bit better fuel economy on this tank. I have about 50 miles on the trip reader and the needle is at 1/4 from full. I think maybe the sea foam is helping clean up what ever else was clogging it up.
I will keep you guys informed.
Also gonna be changing out the chain today.
Thanks for all the input.
#22
#25
#28
Blackdog, I did 130 miles yesterday and averaged 45 mpg. Checked it by 130 mi off the odometer and the pump reading. I have no clue what the fuel gauge was reading.
What year bike do you have and do you know your gearing.
My tach needle matches my speedometer needle when in 5th gear with stock gearing.
#29
#30
So I just got back from a 60 mile run. The fuel needle hit reserve at the 100 mile mark on the trip OD. I kept it around 5k rpms for most of the ride, till I hit the twisties. Man I love this bike.
I popped the tank afterwards to check for any leaks and found none. I did how ever notice that the rubber boots to the air box are separated in parts. Will this cause the unstable idling? I can silicone them up "wich it appears someone did before" and see if it runs any better.
I also pulled the air filter just to double check again. There is a little bit of dust and dirt on the inside of it but not much at all.
While I was doing that I notice that at some point there was oil leaking in the air box from the top portion of the box and down to the bottom of it. There is absolutely no oil on the air filter though.
Any ideas?
Thanks
Any ideas?
Thanks
