Low Gas Mileage
on
If the plugs are that color and indicate proper firing - I'd be looking for more leaks
at the "T"s feeding the carbs or the float levels might be set wrong and it's dumping
fuel. Check when it's running and fuel is coming through the petcock - see if there's
any coming fuel and gas smell from down under the carbs
Glad to hear not a CA bike.
Next question, when was the last time you checked the air filter? They are hard to get into on these bikes but a small furry guy may have set up shop in there.
If it's dirty, it would idle and run ok but would be like choking it at higher revs.
100 mph does suck fuel too.
Incorrect float settings will waste fuel, usually by a rich mixture, which sounds like you don't have, or by overflowing thru the carb vents, which I also don't think you are experiencing.
I'm thinking speedo error.
One note, my petcock was leaking at the tank flange and I never smelled the fuel I only found it when I saw residue on the frame where the fuel was running down.
But..... I have never, even with hard ridding, including lots of 100 mph runs, ever gotten less than 35 mpg.
