Light smoke, running rough...
OK, I had the bike out over the weekend and was running very smooth (135mph) and then it just acted like it was out of gas. Sat on the side of the road for 3-4 minutes and then started up fine and got almost home when it did it again. This time it would not start at all. I had to trailer it home. So i pulled the carbs and put 2 cans of cleaner in them and blew them out with the air compressor. Put the carbs on and it ran great for about 4 minutes and quit. Would not start at all. Today I tried it and it only started with 1/4 throttle, not at all with the choke on or off. Now it sputters, will not stay running with out the throttle at 1/4. It is also starting to smoke just a little, is that just incomplete combustion or a bad head gasket?
I had just replaced the petcock also, the bike is a 1990 with 11,000 miles.
RE: Light smoke, running rough...
Open a carb bowl drain screw and see if fuel runs out. Your bike has a vacuum shut off. There is a vacuum hose that runs from the petcock to the intake. Either crank the engine or use a break bleeding vacuum pump and put vacuum to the petcock and you should get fuel to run from the drain screw. The vacuum hose may be bad.
